No, the plugs are under the individual coil packs which are located between the runners of the intake manifold and are held down by 2 bolts each.dcat151 wrote:It's time to replace the spark plugs on my J30, and I have what I think is a dumb question, but I've searched the site and haven't found an answer. Are the plugs located underneath the plastic cover on the top of the engine? If so, what size hex wrench is needed to remove the cover? (I read a post on this site saying that the I30 uses a 4mm hex wrench, but I don't know if it's the same for the J30.) I'd appreciate any help anyone can give me.
also be careful pulling the coils off. I have actually broken one of them. Try to pull them straight off.yodawill2000 wrote:Be sure to use the OEM spec plugs.
NKG PFR5G-11 Double Platinum.
Others have been known to cause issue's.
Great, now you're give me second thoughts. I was planning to change my spark plugs out in the next week or two. The J is my only car so breaking a coil would put me in a precarious situation.gr8scott72 wrote:
I've changed them at least twice on my 93 and once on the 94 and only broke 1.puck wrote:
Thanks for the tip. I'd picked up the regular platinum NKGs, but I'll go to the store and change them out for the double platinum. I'd like to avoid any issues with the J30.yodawill2000 wrote:Be sure to use the OEM spec plugs.
I'm down to only 5 spares. hehepuck wrote:Ya, I started looking for a spare after I read your post about breaking one.
They are nothing compaired to the rear 3 on a V6 FWD vehicle. I just changed some of a friends car. It was a 1998 Lumina with the 3.1L V6. What a pain.dcat151 wrote:Thanks for the help everyone. I tackled this on Saturday and the car hasn't blown up yet, so I consider that a success. It really wasn't that bad of a job except for the two plugs in the rear: those were a real pain to get to.
