Spark Plug Preference
red coupe89
Car: 1991 Fairlady Z
2005 Nismo Frontier 6spd 4x4
2000 Honda shadow ACE 1200
in the process of pulling my intake for some electrical issues and the cooling lines. going to change my plugs while its easy, ive done some homework on different heat ranges and gaps. im running 8.5/1 on a stillen bottom end with OE head gaskets and heads. twin garrett gt28rs' on 14psi of boost but going to 25psi with nistune over the summer. im thinking NGK PFR6B-11B which are a range cooler with a .036 gap. any thoughts?
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Look on SZ site, go with the iridiums for higher boost appications.
red coupe89
thanks, going to check them out
ThisIsSparTTa
Car: 91 300ZX TT 2+0
red coupe89 wrote:in the process of pulling my intake for some electrical issues and the cooling lines. going to change my plugs while its easy, ive done some homework on different heat ranges and gaps. im running 8.5/1 on a stillen bottom end with OE head gaskets and heads. twin garrett gt28rs' on 14psi of boost but going to 25psi with nistune over the summer. im thinking NGK PFR6B-11B which are a range cooler with a .036 gap. any thoughts?
PFR6B-11B have .044 gap. I did a lot of research on this, and I pretty much found a resounding answer of using PFR6B-11B over the NGK Iridiums because of the way they were designed to go farther down in the cylinder. Also, changing the plugs is super simple minus the back two, which aren't bad. You shouldn't need to wait until doing other work to do them.
red coupe89
since ive bought the car ive only put 3k on it. wasent really a wait to do, just doing things as im doing other things lol. thanks.
