C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Mar 20, 2005 11:47 pm
Keep in mind guys. Daily driving puts you in a lot of cruising situations. The plugs need to run hot enough to burn off deposits from the electrodes. I'd probably run a step up from OEM for a daily driver and tune a bit conservatively to prevent detonation. And then run a colder plug that is more suited for your actual power level for the track if your car serves double duty. Maybe even run a separate map for those so you can make use of the headroom for detonation they should give you.
