Spark plug gap
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
So i did a search and i didnt come up with anything. I got some BCPR6EY-11"s ( Copper plug ) which are a colder spark on the plug and some of the gaps arent the same. What is the recommended spark plug gap on the RB25DET? I looked in the FSM and it doesnt say either.
StricNyne
i bought autolite resistors they r like 1 doller at autozone, for the z32 and i didnt touch gap, i didnt have ne problems with those (copper btw)
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
0.032 is what i was told the proper gap for my Rb25 is I have had no problems with it.
Kansei240sx
sweet. Thanks man.
BoostFab
Car: S13cp, S13fb, S14z
or 0.8mm
sean8564
1993 Nissan Silvia
I used a set of densos which were 1.64 each for a 89 300zx twin turbo.
jdms13rhd
Car: Silvia Convertible, RB30 Ceffy
Do .08 for any factory RB. You will run awsome!!!!
Reignman
Car: 1995 240SX
What plug and gap would be good for a higher powered RB25? I know that NGK 6953 are good for a stock RB.
Carl H
you should not be using z32 plugs.the proper plugs for the rb20/25/26 are from a z31 turbo.iirc i run bpcr7e plugs in my car, but for most sock/moderate power cars bpcr6e plugs should be fine.
Ramius83
Car: 1995 240sx SE
Carl H wrote:you should not be using z32 plugs.the proper plugs for the rb20/25/26 are from a z31 turbo.iirc i run bpcr7e plugs in my car, but for most sock/moderate power cars bpcr6e plugs should be fine.
What is wrong with running the Z32 TT plugs on a RB26? I am running the BKR6E-11 NGK Coppers on mine. One of the sponsors from either this site or another highly suggested those as they were a good cross reference.....
Reignman
Car: 1995 240SX
Yeah from every post I have read people are using NGK BKR5E-11 for a stock engine. Im guessing a BKR4E-11 would be a colder plug and the one I should use.
Carl H
if it works it works, but the z31 plugs are the direct oem copper replacement for the rb motors that originaly came with platinum plugs.also dont use a 5 heat range plug on an turbo rb, if you like detonation then go for it but idealy you should use a 6 heat range on a stock rb motor.on ngk plugs the higher the number the colder the plug so a 6 is colder than a 5 and a 7 is colder than a 6.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Carl I am pretty sure the NGK BCPR5EIX-11 is the stock plug for the RB25. At least that was the concensus in the replacement parts thread.
Carl H
hrmmm, ok well if it works then it works like i said before.i took my stock platinums that were in my rb when i got it to the parts store and told them i wanted the copper equivalents so thats what number they gave me, seems that its also the most popular one used on skylinesaustralia.
Reignman
Car: 1995 240SX
The BCPR6E and the BCPR5EIX-11 looks like they would both work. the BCPR5EIX-11 just has a fine electrode where the other has the V-power electrode. The BCPR5EIX-11 also costs $7 per plug vs $2 on the BCPR6E
