Spark plug gap shrinks
Zurcs
Car: 93 240sx
ok i been running bkr6eix and i gap them at .30 run the car for a while month or so notice the engine running different so i took off the spark plugs and the gap shrinks done this twice and i have another set that came with the car platuims does the same to them also same heat range any clue? i running an sr20det basicly stock
Cone Junky
Car: S13 fastback
BMW e46 328i
I imagine the only thing that would cause that would be the piston actually contacting them. I would double/triple check the spark plug specs (length).
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
i ws gona go with the same info man..did you by chance change the headgasket before you had this issue..if ya did..you might have a thinner gasket issue.
Zurcs
Car: 93 240sx
they regap to 24 i haven't done anything to the motor
mexicanracer03
Car: 95 S15FRONTEND SR20DET and 97 2JZ GT4294/ 93 SC300 Black/ 95 SC300 Green
get some BKR7E and gap them to 30 Try that and see what happens. GL
Zurcs
Car: 93 240sx
thanks guys i bought some ik22 when i took off the BKR6EIX they did not shrink i noticed the ik22 where a bit smaller so i tried them on the engine sounded a bit different better and the motor did not vibrate as much on ideal or around 3000 rpms anymore the ik22 where pregaped at .28
