EniGmA1987 wrote:What made you think to swap the #7 and #8 coils? Ifthey were correct then swapping them would cause a problem no?
This is done to test the coilpacks. If #8 is misfiring and you move the coil, the thinking is that if the coilpack is bad then the issue will follow the coil. If you move the coilpack and the issue remains in cylinder 8, then you have something else going on.
The other way to test coilpacks is to unplug them one by one (plugging them back in before going to the next one) while the car is idling. The idle should change (get rougher). If it doesn't, then you know that pack is dead.
