I have this posted in the Tech section also, but I thought I'd also ask the Hardcore Murano guys...
I'm going to attempt to change my spark glugs this weekend. In the process the throttle body needs to be removed. Because it is a "drive by wire" throttle body will I need to perform the following: 1)ECU Reset 2) Acc Pedal Release Position Learning 3)Throttle Valve Closed Position Learning
The last time I removed the throttle body for cleaning, a CEL popped up......took it to the dealer.....they had to Relearn the idle RPM...and reflash the ECU and upgrade the software.
If I have to go through this again......I might as well have the dealer install the spark plugs. Any one try this?????
