NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Mon Mar 10, 2014 8:18 pm
Definitely not the plugs. the 90s had head machining issues from the factory, could be that, or could be that your rings are slightly more worn, or that your TPS is a couple degrees off from true, or that your cats are slightly blocked, or the oil you're running. Two identical 24 year old cars, even well maintained could easily have a differential in HP of 10% or more. Metal isn't everlasting, plus if the 2 cars are identical apart from having had the exact same life then there shouldn't be a massive difference in how they "pull". The reason you should use the OEM plugs or a fitting replacement is because the plugs in the VG are longer than other "standard" plugs so sticking in shorter plugs puts the ignition source for the fuel/air mixture in the wrong place, this causes the car to lose power. Can autozone plugs be ran in a VG? Yes. Will it always cause problems? No. But if you want your car to run right than you need to run the OEM set.
