i will do that and i suspect that its the stock coil needing to be replaced but i'm going to take my time this time around now that school started again (IT school son). I'm also going to try going suck through again instead of blow through and see how it works. Most likely the car won't be on the road until spring. I'll started a build thread when i have everything running perfect. thanks for all of your replies!240sxvaj wrote:You should check your ecu, since it's from emance i heard it gets loose something and can pop out of place. open up the ecu to make sure that it is in place. i think thats the problem since all of a sudden it just acted different.
if not then make sure all injectors are connected and you have good spark wires or dizzy.
