spark plug #4 has excess oil around the thread, what's the problem?
sk8kei
only #4 has this problem....., then all of the spark plug tips...don't look good either, it's grey color, cover with grey graphite powder... so what it's indicate?
USsil80
what motor year .. info helps alot ... my if it is a kade .. the valve cover gasket might me letting go..not the head gasket.... mid did this and leeked oil around and into the hole for the spark plugs
sk8kei
Yes, It's 92 KA24DE. so what exactly affect the engine efficiency if it's the valve gasket leaks?
SeVa-S13
Car: '05 GTO 6spd
Not particularly, but leaking oil is never really a help to anything as it looks bad and will probabaly drip onto your exhaust manifold (like it did mine) and smell bad. =\
hachibroku
Car: 98 240sx s14 MO Betta
Its Probably the valve cover gasket. i see it all the time with all types of cares.
