Ender_Zero »
https://forums.nicoclub.com/ender-zero-u15960.html
Wed Apr 20, 2011 8:08 pm
Hi guys, I've done some extensive searching, and couldn't find anyone with my particular problem.
History: I'd swapped a 93 KA into my 91 S13 coupe about 6 months ago, it was running like a champ until about 2 months ago it started breaking up at WOT near redline. That was the only indication that anything was going wrong. One night coming home it lost power and died. I tried starting and there was no indication that it wanted to start at all. I was close enough to push it all the way home (no small feat with a welded diff...turns are killer.)
So where I'm at right now: Its a spark problem. I checked the spark coming out of the coil by grounding it on a nut, spark was orange but thick and seemed strong. Pulled #1 spark plug and popped the coilwire back in so I could see the spark plug at work. No spark whatsoever. I tried the other plugs. Nothing.
Its got to be the cap and rotor right? Wrong. Just replaced both of those today and tested the plugs again. I've made double sure I've got the cap on right and the wires in the right place. I can't see it being plugs or wires since it was running ok other than a bit of break up at WOT... All four can't have gone wrong at once, right?
I've checked for connections getting unplugged, everything looks good. Grounds look good. I'm thinking now that its either the dizzy or the ecu... Can either of those stop the spark getting from the rotor to the cap? I can't think it would, since its almost all done mechanically at that point...
I'm completely stumped. Anyone have any thoughts? I appreciate you guys!
-Ender
