spark fuel and compression=not running???
1995240sxSE
Car: 1991 jeep wrangelr and a 2004 ford taurus
Ok I got spark and compression. I am pretty sure I have fuel. I fulled off fuel rail and pointed it up. cranked motor. I didnt see anything spray. But there was the smell of fuell and the bottoms of injectors had gas on them! Should I see the injectors SPRAY or what should it be like. I am getting adgitated with this!!!
S13FX
Car: '69 l20b Dimeski :)
Hey bro you already have a similar thread to this one but with a differ title,
If you want I can combine them both and change the heading for you.
But lets try not to post the same thing twice .
Thanks,Mike
1995240sxSE
Thats cool, sorry If I double posted. I am just really annxious to go for a ride. I need some fresh ideas for why my injectors arent spraying.
I contacted rc engineering to see if fuel injectors produce a visable mist they said yes. I have no visable mist. What could be the cause of this. The fuel pump is cutting on! I have to check voltage on injectors, but I am almost positive that the injectors them self are fine! Could this be an issue witha vent line to gas tank. I yanked all the carbon canister lines out, So I have one that is down by the slave cyl. and one I think on the other side. Do those gotta be capped? I dont have a fuel pressure gauge or anything like that. I do know I am gettting fuel to the injectors cause when I checking to see if they spray there was fuel on the bottom of injectors it just didnt seem like enough to start a car!
rotorimp
Car: 02 Xterra, 60 IH Metro
Go to checker or autozone and get a noid (led that lights up when the injector is firing) or you can use a mulitmeter and check to see if the injectors are getting a signal.
1995240sxSE
a noid, do they rent them?
rotorimp
They are cheap--10$ maybe?
esahuque
Car: 95 240sx KA-T, 04 frontier
I had the same problem with my motor swap. It ended up being my FPR was clogged. did you ckeck your vac to your FPR? or made sure it was hooked up right. you did pull the head right? you had to of messed with it when you pulled your head off.
1995240sxSE
I had fuel lines backwards! But when swithcing lines around i messed somthing else up. no my starter just runs. sounds like an electric drill running. I think I pulled the ground off. But it shuddered so I am a little more optimistic!
