ghx407 »
https://forums.nicoclub.com/ghx407-u51111.html
Fri Jan 08, 2010 6:47 pm
Two days ago I got on the 240's pedal WOT and when it hit about 12 psi, it hesitated pretty seriously. Since the car was tuned in Puerto Rico and had never before been boosted in 40 degree weather, I immediately thought that the AFRs had leaned.
So I upped the the fuel about 10% with the SAFC and turned boost down from 15 to 10 psi.
The problem persisted, so I returned the SAFC to its normal settings.
I then removed the plugs, which looked normal. They're about 1.5 - 2 years old, NGK R5671A-8 gapped at .042. (Up until now they had performed flawlessly, including about 10 track days.)
I also tested cylinder compression and got 155 - 160 across the board with 8.8 pistons.
I lowered the spark plug gap to .032 and was able to maintain 10 psi at WOT. When I increased boost to the regular 15 psi, the problem came back.
Tomorrow I'll lower the gap to .028 and give it another go.
Besides violent hesitation on WOT at boost over 10 psi (any RPM), the car runs great. Are my spark plugs on their last leg, or does cold weather affect adequate gapping?
