spare tire wobbly
towncarblue
Car: 2002 Nissan Pathfinder
i have a 2002 nissan pathfinder 4x4 A/T.
i have a spare tire , the type that is under the bumper/vehicle .
its loose and wobbly. looking at a older model qx4{1999} parked on the steet i
noticed that there are some rubber pieces that hold the tire in place.
mines seem to be missing .
i tried looking at courtesy parts but couldnt find it.
im not too sure but i believe they are called spare tire stopper?/
what is the part numbers i need to order this ??? im not trying to go to my local dealer {rip off artists}
atraudes
Car: 2001.5 Infiniti QX4 4WD
I know exactly what you're talking about; I was just looking at them this weekend. I took a look at Courtesy and found what I believe is them. Looking at the third diagram down, I think it's the 57276EA and 57276EB parts. I'd give them a call and confirm.
towncarblue
yup those are it...
as it turns out i found them on the inside rim when i took off the wheel . the bolt or clip that was supposed to hold them to the frame is gone but
the mounts aint broken.
i need to find a way to mount them back
nickelghandi
Car: 1999.5 Nissan Pathfinder LE 4X4 (rusted out: sold)
2004 Nissan Pathfinder LE 4X4
1998 Volvo S70 GLT
2001 Ford F150 XLT
You can just tighten your spare up a bit and it should be fine. I have run like that for over a year and have had no problems with wobbling or lowering the spare.
Hawairish
Car: 2004 Nissan Pathfinder SE 4WD
P/N 01553-09321 (57210H in the parts diagram, but the part has been superseded to 01553-2DR9A). They're all over eBay. It's a common part for Nissans used on bumpers, wheel well liners, and other exterior/interior trim pieces. If you look in those locations, you'll probably see some missing. Buy a few.
I also had to replace the ones for my spare.
donald
Car: 2001 Infiniti QX4 (RIP, 2011)
2010 Pathfinder LE
towncarblue wrote:yup those are it...
I bought a pack of push-retainers from Amazon to fix one of the rubber stoppers underneath my truck.
You can find them here: http://www.amazon.com/gp/product/B0093R ... detailpage
Measure the hole where the push-retainer would go to make sure it's the right size. Mine measured 8mm.
I used the other push retainers to fix other plastic sheaths or covers that were missing the retainers.
Good luck!
