Spare tire for Q50S?
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
owentwo
Car: 2014 Infiniti Q50S
I would like to get a spare tire for my 2014 Q50S with 19" wheels and run flats. Is this spare available? I had one dealer tell me yes, and another no. Who is right? If it is available, does anyone have one?
audtatious
An Infiniti dealership should be able to order the parts for you. Did you get a price from the one who said yes?
RicerX
Car: '20 Titan Pro4X
I'm going to go ahead and bump this as well.
Eikon
Car: 71 240z, 93 Supra TT
The dealerships do sell spares, but to get the spare you need the tool kit, some plastic pieces, mats, and other junk.. The prices for those are crazy from the dealer.. I forget exactly, but I want to say I was quoted over $600.
To anyone reading who hasn't picked one up yet. The option for the spare tire is only a couple hundred bucks when bought with the car.. so pick one out that has the spare tire kit included. Even if you never use it..
If you already have your Q.. If 19's.. dump them asap. they are garbage and crazy expensive to replace. Get a set of good tires and buy a can of fix-a-flat or something in case of emergencies. You could try to find another spare tire with the correct lug pattern and offset, but then you would have to get the correct trunk mat because the tire sticks up a bit higher than the mat lays.
Return to “Infiniti Q50 / Q60 Forum”
