How much? And do you have the crank only or a whole short block or such? I'd probably be interested in that too...Nismo1182 wrote:I got a crank for sale.
Well I should have a new set of flywheel bolts by the end of the week. I'll clean out the crank holes and try those out. If it really is messed up I'll try the re-tap; sounds like a good idea. I'd like Nismo1182's crank as a backup; I don't know any of the machine shops around here or anyone to ask for recommendations about a good one. Nismo, email me if you could. [email protected] .float_6969 wrote: That should be the eaisest/cheapest route. If you're in doubt call a local machine shop/engine rebuilder and ask them. They are probabally going to have more hands on expertice in that area.
Is it that easy? I have a tap&die set with the next metric size up, but I'm a little worried about drilling 8 straight and true holes and getting the threads in straight as well.r34 gtr wrote:you can tap it yourself, just go to a hardware store and get one in the size you need. drill it out a little, tap it, bolt things back up and call it a day.
now im worried about putting my flywheel on.. im going to be so careful itll take me a week. good luck though!- tim
That drill sounds awesome, one of those would have made my life easier a number of times. I actually have a standing drill press in my garage so I may try that out if I feel squirrely about using my hand drill. I'll measure the thread depth in the holes to see if the longer bolts are viable.r34 gtr wrote:haha, okay. my dad got a new 19.2 volt craftsman drill and it has built in levels so you can tell what angle your drilling at. or if you could use a drill press that would be even more awesome. im sure you can find one big enough somewhere.
the longer bolt idea isnt too bad either, but make sure you have at least as much good thread left as you did with the old holes before they were stripped.- tim
75 shipped? If so then its a deal, just let me know where/how to send the money. If not, how much shipped?Nismo1182 wrote:75 for the crank.
If the long bolt idea doesn't work I'll do this. Or actually, use Nismo's crank and do the larger bolt thing to my old one when I get the time. The new stock bolts are already on order so I might as well use them.r34 gtr wrote:a standing drill press is the way to go. drilling by hand will be such a pain. itll wear your arms out as that crank isnt exactly made of soft metal.
Sorry man; I didn't notice where you were located. Be safe.Nismo1182 wrote:Not 75 shipped, ill find out how much though. Damn hurricanes are making things difficult down here.
