hey nghtrain88 or should I say mike.....nghtrain88 wrote:Simmode1 just meant that they are awfully skinny wheel sizes. Those are pretty conservative offsets though so without spacers they'll probably look sunken in. Someone correct me if I'm wrong, but with 7.5" wheels up front you'll probably want a spacer that'll get you to at least a 20 offset without having to worry about rubbing. Not entirely sure about 8" 32 offset in the rear but I want to say it's close to stock on an NA so you'll want either a little lower offset or spacer there too.
TTkickedin wrote: if you bought a -10mm offset wheel and a 30mm spacer, your wheels would fit like a +20mm offset wheel.
