ken in az wrote:Adapters are different the spacers, they actually bolt to the hub and have another set of lugs to bolt the tire on.
Actually, what you're referring to is "bolt on spacers", the words "adapters" reflects a change of the bolt pattern.
IMHO, spacers and adapters aren't pure evil, but you get what you pay for as with any part.
Bolt on spacers may require that the wheels have "cavities" between the bolt holes so the original studs have somewhere "to go". If you use a "slip on" spacer, you may need to use extended studs.
Do the proper research, buy quality products and use the proper installation procedure and you should have good results.
