lifewater wrote:Sorry to thread jack in here, but what are adapters? I was told spacers are unsafe, and adapters are the safer/stronger solution.
false, your tires can always be aligned, and usually uneven tire wear is the problem. Either I'm not understanding or your pulling this out your hiney, haha.mech_E wrote:The problem with spacers is you increase your scrub radius and wear your tires faster, due to the offset of the suspension geometry with the center of the wheel.
The scrub radius actually has nothing to do with tire alignment but has to do with the king pin offset of your wheel and where it connects with the center of your tire at the contact patch. When you space out the wheel, the scrub radius actually gets larger and as you turn your car at lower speeds, the wear on the tire actually increases, by an increase in deformation of the tire. This is also due to the tire rotating around the kingpin axis, which as you rotate the wheel the movement of the tire is like a truncated cone. As you space out the wheel, it is actually harder to turn your wheel due to the increase in the scrub radius. When cars did not have power steering, the scrub radius was very small, so the car was easier to steer. Now, there is power steering in cars, so the scrub radius is not taken into as much consideration. The scrub radius is also affected by many other things such as wheel diameter and offset of wheel compared to width. All in all, it is not a big deal and probably doesn't wear the tire to a noticeable degree. I was just putting in my two cents of how wheel spacers effect the wheel platform. I actually have spacers on my car, but it is always good to know how changing something on your car is going to affect the suspension geometry or your contact patch. It is the same thing as the belief that as you increase the width of the tire, you will increase the contact patch. But this is not true due to P=F/A. All it does is widen the contact patch, but narrow it in the longitudinal direction, to where there will be a change in the pneumatic trail as you turn. This will then affect the lateral forces that your tire can handle before the slip angle goes to **** and you lose grip.Im sorry for this long explanation. I just wanted to explain why I said what I said and how I did not pulling it out of my "hiney."smocan wrote:
them.
I go to Colorado State University. The engineering school here is okay, but could be perfected. CSU is one of a few schools that offer a motorsport engineering degree, so if you are interested in motorsports, it is not a bad school. I like the major a lot, but it is a lot of work and have to be dedicated to putting all your time into it. I would say if you are wanting a motorsport degree, go somewhere else and then have them pay for you to come to CSU and get your masters.babababutler wrote:what school do you go to and how do you like your major im just now graduation highschool and looking to go to a four year 4 mechanical engineering still undecided on which school
Ok thats all good an all... understand your explanation... but still, spacers really don't do anything in the area of tire wear. And yes, low offsets would act in the same way as spacers.mech_E wrote:
The scrub radius actually has nothing to do with tire alignment but has to do with the king pin offset of your wheel and where it connects with the center of your tire at the contact patch. blah blah blah...
