SPACERS
240RB1
Car: 03 Infiniti G35
92 Nissan 300ZX Z32
95 Jeep Grand Cherokee ZJ
i finally got a set of tt z32 wheels but found out that the fronts rub how big of a spacer do i need to buy to make it quit rubbing? i havent put the rears on because im installing my bushing set so does anyone know if the rears will rub i have k-sport springs and kyb gr2 struts.
adrianfromthecastle
Car: 1992 Nissan 240sx
they rub? really? Ive never heard of oem z wheels rubbing on suspension before, their offsets aren't that bad...
what tire size are you running?
240RB1
92 Nissan 300ZX Z32
they rub on the strut they are the stock tire size 225/50/16 its the tires that rub not the wheel itself the offset is 45 up front 16x7.5 and 16x8.5 in the back with a 35 offset
nismofly
Car: 89 Nissan 240SX Hatch
i think they clear with something as small as a 10mm, but you could run like a 25 for the sake of fitment
240RB1
92 Nissan 300ZX Z32
nismofly wrote:i think they clear with something as small as a 10mm, but you could run like a 25 for the sake of fitment
Are you serious i think something less than 5 will work but i wanna be sure
nismofly
the smallest ive ever heard anyone run was an 8mm, most people run 10-15, but you can run quite a large one if you wanted to...my wheels are 16x7.5 +22 and i wouldnt want an offset any higher
240RB1
92 Nissan 300ZX Z32
why did you move my thread not to be rude or anything but noone ever checks this area thats why i posted on the 240 area and not the wheel and tire area.
nismofly
i didnt move it
if more people wouldnt use that excuse though then more people would post here and there wouldnt be an issue
240RB1
92 Nissan 300ZX Z32
i guess what your saying is true thanks for helping me though
adrianfromthecastle
if you're planning on running 10mm spacers or less, you'll need extended lug nuts. Honestly, I dont trust 5mm spacers on stock studs.
But they do sell 15mm bolt ons, but yeah, like what Nismofly said, I'd go with 25 all around
