Spacers question
pdubsq70
Car: 2014 Q70S
Is the wheel bore the same on all Infiniti models?
I purchased some spacers off eBay from the same seller in a previous thread I saw here. I got a lot of vibration and found the quality very cheap. One of the spacers I had to torch off because the extended lugs on the spacer kept spinning. Long story short you get what you pay for. Do any of you know if I get h&R spacers for ie a q50 it will fit on my q70 2014? I dont see an option for the q70 on the site. I don't see the option for q70 from reputable brands anywhere really.
Thanks in advance to anyone that can help me out.
Ilya
Welcome to the forum. Look for spacers for a 2011+ M37/M56 as it's the same car, not just a Q70, if you aren't already. Also, I believe RED_DET (one of our vendors here) can get you nice H&R spacers that'll fit, etc. He owns the site TunerzStore.com.
To answer your question though, I know my wheels fit on both my M37x and my M56x (my old 19's)...so I would assume if not all Infiniti's are the same, then definitely all M's (or Q70's).
pdubsq70
Car: 2014 Q70S
Thanks for the reply ilya. I did check that site out but I think it does not offer shipping to Canada.
Ilya
Ahh, didn't know you were in Canadia :P.
The last part of my post should apply though...pretty sure you're okay looking for any year M, at the least, as the wheels lined up fine with the same hub-centric rings on both of my cars.
beachbum718
Car: 2011 Infiniti M37 S
Ichiba v1.where u replace the stud's. The bolt on ones are suspect.make sure you torque any spacer down to correct specs
pdubsq70
Car: 2014 Q70S
Yes sir I'm here In The great north Ilya.
Thanks beachbum I'm going to look into the ichiba v1, I've got my BC racing coils on and I can't stand the tucked look
k67p67
Car: 2015 Infiniti Q70 Premium
2017 Nissan 370Z Nismo Tech
Pretty sure all late model Nissan/Infiniti have 66.1 center bore, 114.3x5 bolt pattern and M12x1.25 lug thread pitch. I prefer the Ichiba v1 or v2 depending on how thick your spacer is.
Ilya
k67p67 wrote:Pretty sure all late model Nissan/Infiniti have 66.1 center bore, 114.3x5 bolt pattern and M12x1.25 lug thread pitch. I prefer the Ichiba v1 or v2 depending on how thick your spacer is.
This.
