Spacer Size? 30mm Z32 calipers + S13 SE wheels?
zooopreme
Car: 1993 240SX (S13)
I wasn't sure where to ask
...but here, I need to know what kind of spacers I will need to fit my 30mm calipers with my SE wheels (will provide picture on the bottom). Would I need spacers for the rear calipers as well?
I've searched and I found a VERY old thread on Fresh Alloy that didn't help me out.
Here's the picture of the SE wheels:
allenms240
Car: 1991 Nissan 240SX
You'll need at least 7mm spacers in the front. Not sure about the back.
I I got some 30mm calipers up front and needed the spacers. I would recommend bolt on spacers though, get some 25-30mm ones that bolt onto the hub, they're safer than the bolt on ones.
zooopreme
First: Thank you for replying after many views! I was going to bump it later tonight if nobody really answered.
Second: What's wrong with a 15mm? Isn't 25-30mm kind of overdoing it?
allenms240
Size is a matter f perspective. I like my wheels to be flush with the chassis, so I got the 20mm up front, 25mm in the back.
The only problem is the oem studs are a little too long, so you'll have to cut them shorter, I used a grinder to do this.
