karay240 »
https://forums.nicoclub.com/karay240-u11860.html
Wed Feb 25, 2004 1:51 pm
No, they don't have spacers. They actually bend more, so you have to grind the stoppers in order to get more steering angle. Not sure as to how they're built differently, though. I've actually never seen the tein ones, so I really can't tell you the exact differences. I was just wondering how much I should grind off. The guy at the shop I bought 'em from told me that a little over 1cm would be good, but also told me that it wouldn't be a problem if I just grind the whole thing off.
The only time you're going to turn the steering wheel all the way would be when you're in a parking lot, or in full counter steer during a drift (right before you spin out). Do you really want to max out your steering during a drift? Didn't think so.
That being said, I don't really see why having too much steering angle is going to hurt you. However, I understand where you're coming from 'cause I don't really want to have a rubbing wheel either.
Take this rambling however you like, but It won't be a serious problem like a tire rubbing the fender when you lower your car too much w/ wide tires. I doubt that you'll have any serious problems w/ the spacers in. (at least your's are reversable. . . if a grind too much off, its going to be permanent. lol)
