spacer question
240sx_in_209
Car: 89 240sx.... 93 coupe
whats is the biggest spacers i can use on an s13 4 lug hubs?? i seen ppl say 10mm and other ppl say like 7mm
ashibah83
Car: 93 SUPA BLACK COUPE
with stock studs???
you could always use bolt-on spacers and go like 30-50mm
240sx_in_209
lol yeah i know but on stock studs?? how big i can i go?
simmode1
Car: Red '95 S14
240sx_in_209 wrote:lol yeah i know but on stock studs?? how big i can i go?
You should be able to use 5mm's safely on stock studs. 7mm is pushing the limit.
240sx_in_209
dam so for a 10mm spacers i would need extended ones already
ss82480
Car: 1992 240sx Coupe
If you want to do it safely, I would highly recommend getting some quality hub bolts as well. Nismo's are real solid imo.
240sx_in_209
yeah i know i got 300zx brakes but i need a spacer and i used some washers just to see how much would i need and i need like a 10 mm spacers anything after than i seen are all like close to 100 so shoot
adrianfromthecastle
Car: 1992 Nissan 240sx
