Spacer question aka for infinitgkid
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
suby01
Car: 2007 Infiniti G35x
infinitgkidsaw that you were THE ONE to talk to about this....
searched and i have no idea what to get or where to get them and what i need. i want to make it look shexyyy. currently 245 19s
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
The current width and offset of your wheels needs to be known in order to give you correct information on what size spacer.
suby01
ok stock is 225/55/17the wheels im putting on are
245/40/19 non staggered. what spacers do i get and from where thanks.
JeromeS13
Car: 2008 Subaru Impreza STI
Those are tire sizes, not wheels sizes/offsets...
suby01
ok so how do i get that ??i guess ill have to look at my wheel order.
suby01
ok this is what i got..........
19x85x114.3/120 et40
245/40r19y
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Did you buy them yet? If it's possible to buy it with the correct offset, that would be better than using spacers. Your call, price, availability, and other things could make your setup a better choice.
+40 seems a little on the high side. I think my rears are 8.5s with a +32 and I could still use another 10-15mm to be flush.
RED_DET
Vendor
2011 Infiniti G37x
You should be able to get away with a 10mm spacer.
http://www.optionimports.com/ns-50210-a057.html
Offsets are completely different on the coupe. There is about 1-2" more fender flare which allows for a more aggressive offset on the coupe.
suby01
as you can see i have no clue about the spacer thing.....
yes its the same rims that i got last year.. just for the summer i want to get spacers, and before i put them on.
so those are my specs i guess. so im just wondering what i can get to make it look "more good hotter". yess that is a word.
if anyone know ebay or w.e store.... thanks
Sentientbydesign
96 I30 - Sold
RED_DET wrote:Offsets are completely different on the coupe. There is about 1-2" more fender flare which allows for a more aggressive offset on the coupe.
I forgot about that. Gracias
suby01
alrite. so 10 or 15 mm ??their the same price.
RED_DET
Vendor
2011 Infiniti G37x
10 to be safe, you don't want to end up having to roll your fenders. the offsets on the wheels are +40mm plus the 10mm spacer and the offset is now a +30mm. if you add a 15mm spacer the offset becomes a +25mm. the lower the +offset the further it is pushed outward. when I had the 18" coupe wheels on my sedan, they were 18x8 with a 30mm offset. They were flush with the fenders and looked good.
suby01
red.. thanks for all your help im going to order the ones you recommended from that site.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
+1 for Hubcentric spacers
10mm is about as close as you can get to flush without rolling those fenders...and it may be close enough where you want to roll them anyways.
I dont know why people are so sketched out about rolling their fenders... Not that big of a deal.
mistanave
Car: 2003 G35 Coupe 6MT
hi, i am looking to get spacers (10 or 15mm) for my coupe as well (i want them as flush as possible)...what would you recommend with these wheels?18" x 8.5" +2818" x 9.5" +26i'm not 100% sure of the offset (need to check my original invoice when i bought my wheels 2 years ago)...this was what the guy who ordered my wheels said the work rep recommended for my coupe but i noticed that my brembo calipers have some chips on them maybe due to clearance issues...thanks for any info...
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
