elwesso wrote:The gas tank is in between the rear seat and the trunk........ So you dont have a lot of space back there...
Heres a picture of what im talking about, its from a 94 Q but its the same basic idea.......
one ton garage wrote:If you're going to be mounting subs to the rear deck, you're not gonna be far off from fabricating a new panel anyway, so you can also raise it a tad to give you a few extra inches. It's also possible to use those new slim subwoofers, such as Pioneer's line that's supposed to be pretty dang good from what I've heard...
can anybody confirm this 12"edness with a measurment. also, how much area is on the rear deck, do I have at least 35"X18"Falkdesigns wrote:There's actually a good bit of room on top of the gas tank. Y33's come with Factory rear Shock Tower Bar, but even on that you've got about 12" of room above it. I've always thought mounting a bass tube on the RSTB would be stealthy and all the boost you need.
Q, I'm guessing your talking about the wiring to the little amplifiers on the bose speaker right? is there 4 wires? I'm guessing it's power, ground, +signal, -signal. so bust out a multimeter and check resistance for a zero, thats ground. then check voltage for 12Vish thas prolly power. then the signal wires are the other two and it doesn't really matter if you have them wrong it won't hurt anything it just will be 180 degrees out of phase. when I get my Q in a couple weeks I can confirm this as I'm pulling the whole BOSE system out.Qproject wrote:anyone have the diagram to the rear deck speakers ?
The eD 16Ov.2's are aprox the massiveness behind the cone, just more cone area. I bet those solo barics were pretty loud huh. how bad did the trunk rattle?heywier427 wrote:i put two solar barick 10s in my rear deck in my G50. it was hard,and im good. ive never seen the trunk on the Y33 but 15s are gonna be tough/impossible. maybe it was hard for me cause of the massiveness of the L7s but i wish you luck.
slinger5150 wrote:Since its a Bose, they're not regular speaker signals, they're low level inputs.
Can you post picks of your design and installation?heywier427 wrote:i put two solar barick 10s in my rear deck in my G50. it was hard,and im good. ive never seen the trunk on the Y33 but 15s are gonna be tough/impossible. maybe it was hard for me cause of the massiveness of the L7s but i wish you luck.
