BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Tue Feb 05, 2008 9:16 am
This may not be an actual defect, and is merely a character of the fuel injection system. Let me explain; Every once in a while, my car will "fail to start" after two or three compression strokes. Because the car usually starts after roughly two compression strokes, I instinctively let go of the key. This is NOT a defect; it is caused by several factors including coolant temperature, crank position at the time the starter begins to crank, residual fuel pressure, coil pack residual charge, ambient temperature, fuel temperature, and readiness of the computer depending on how long you waited to begin cranking as you turned the key to the "on" position.
Are you allowing the car to crank for a bit longer than usual, or just letting the key go after one second (as a reflex action since it usually takes one second to start?) Every car I've ever owned (new and old) does this. The fuel pump failure was manifesting itself as a failure to start regardless of how long you allowed the car to crank upon initial key turn. (correct me if I'm wrong).
