okay so let me start of my stating what i am running
1993 240sxca18detstock alternator3"dp3" exhaustblitz SUS filterstock catilyzerNO BOV-" blitz valve crapped on me"STOCK ka FUEL PUMPngk bkr6es11 currently running bcpr7es11self prepped harness," only extended maf and droping resistor."
okay so the motor was recently swappin in as of JAN 05. normal first start up phases, Priming and start up.
1) from the time of first start up till i actually had the motor running it seemed to bog at really low rpm even after i set timing to 15 degrees before tdc. I noticed that the motor ran worse after it had already warmed up so i tried sourcing problems from there, Ran ecu codes and got 23 (idle switch) and 45( leaky injector) weird thing was that i didnt have any leaks or debris anywhere near my injectors or fuel rail.
2) i continued to commute the car/motor to work almost everyday for about 2 months. started noticing weird reactions when i use random accesories in the car. At night when i turned on the lights, or when i turned on my electric fans it would bogg down really low ( 500rpm) sometimes it wouldnt react at all and run normal. I bought a boost gauge to see what i was boosting at and how much vacume my car was pulling, seemed normal.
3) under boost, the car would run fine. I'm not shure if it is the fact that i have 3" dp and exhaust on my car, but it seemed to lagg until about 3,000 rpm almost felt like the when im reaching boost the car studders for one moment.
4) i had just gotten off of work and went to a friend house about 20 minutes away from work, i had hte car sitting outside of his house with the turbo timer countin down 30 seconds when i noticed the car wanting to die, when randomly the car almost droped idle compleetly and then continued to idle normaly. that to me seemed like the beginning of the serrious issue with the motor running. about a week after that first incident i was leaving from home and my motor starting craping out in 2nd gear, idle was droping even when i applied the accelerator/gas. the car died slowly and i pulled it over. waitied about 2 minutes and tried starting it, FAILED and just kept turning over. finally after about 5 minutes it began to start to i kept the ignition turning and it started, i made it back home and parked the car where i began to try and self giadnose the problems. I changed my bkr6es11 in for the bcpr7es11. i noticed that the 6's heat range plugs were compleetly black arround the threadding and white in the center. I was told by a friend that it meant i was running lean, then later that day a friend came over to help test the fuel pump to see if it was priming before start. IT DID but only 3 times out of 10 trys. I then tried to self diagnose the fuel pump isssue, i'd wait to hear if the fuel pump primed before i started the motor. When i would hear it prime i'd try and start the motor, the motor would start and idle for about 10 seconds then die, and this happened about 10 times in a row... the motor since then hasnt ran past 20 seconds at one time....
i really dont know what to conclude to but these problems. so any help would be much appreciated from you guys/girls here on nico.
you can reach me on aim at d0wn5h1ft or my email
[email protected]
brandon
