Sourcing front upper ball joint
Purplehaze
Car: 95 300zx na
Hi all, new to these cars, looking to fix a loose upper front ball joint, but can't find the part anywhere online. Is this a dealer only part? Is it built into the part that bolts to the strut? Never had this much trouble trying to fix a ball joint. Thanks in advance.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Purplehaze wrote:
Wed Jun 05, 2019 5:02 pm
Do you have a picture of what you are replacing?
Z32 do not have upper ball joints, they use a upper control arm with bushings and they do not directly attach to the "front strut" (in this case front shock).
