zmannz »
https://forums.nicoclub.com/zmannz-u23244.html
Tue Jun 10, 2008 3:34 pm
Well, I went to four parts houses in town today and couldn't find the right kind of spring compressor/"valve lifter" to remove my valves. Poo. Anyways, I found the Jun ti retainers, 440 dollars on sale is a little high for some feather light fancy shaped washers. I will stick to oem. I found out about the z32 spring option here locally today too, and the local sound guy is obsessed with vg's and z cars, so he is hooking me up with some extra hd springs he has. I am hoping my valves and guides are still plenty tight. I am not spending a grand on friggin' after-market valves unless my **** is totally shot. I think my red line increase will be fine on stock cams with adjustable gears and the heavy duty springs. Working on figuring all that out soon.
In other news, I was very impressed with the design of the nissan s13 dash under side and cover. I was very frustrated removing the dash from my rx-7, it was all attached to the wiring harness and all one piece, it sucked *** getting it out. I pulled the entire dash and all pieces in it, down to taking all the ductwork from the blowers and dampers, and removing all but the dash bar and the heater and a/c cores, AND the entire wiring harness, all in about four hours. And I labeled every single connector and made new pin-out drawings for everything in the harness I am using and converting/rewiring to get power to the fc chassis and lighting.
I have to get my long block done, get the dry sump system on it, get everything in the engine bay mocked up, then do a test fit of the motor and transmission to get my mounts made and cut into the firewall/fenders/subframe if necessary. Only after I do that can I get to work on a new dash(gonna be vacuum formed fiberglass with cf wrap) and start putting the s13 harness into the fc chassis and wiring up my ****. I am going to build a complete car domain page while I am in downtime waiting for the motor and stuff to get done and get the credit cards paid off again (just put my whole 600 dollar stimulus check into my credit card account like gw didn't want )
