Oh, in all the slapfighting I was watching take place, it was easy to read this and not comment. Thanks for chiming in, I was hoping you might have some input. (And for the record, I -am- ordering the Tokico's, I just have to wait until I get my money refunded from the online places.)Q45tech wrote:The only problem [besides life] in after market or off brand [non oem] shocks is how do you actually measure the compression and expansion parameters to see if they are even close to match vehicle requirements.
Rears at 1 foot per second rate: 186-251 pounds resisting expansion48-71 pounds resisting compressionThe higher numbers are brand new The lower numbers are worn out and exhausted.Hopefully one sees that the shocks should be ~~~ 4x stiffer to pull out than to push in.
The other problem is the entire range of the shock is 7" so from the midpoint ~~ 3.5" so how do you pull in 0.3 second and extert 250 pounds smoothly. Impossible without a $3,000 test machine.
How tough are front shocks to replace, for your typical "shade tree" mechanic type? The friend of mine that's willing to take care of them for me says he shouldn't have a problem if I can get the parts and a spring compressor, as he's done shocks on a lot of cars before, but I'm wondering if I should see about spending more and taking it to my mechanic? Is there anything particularly difficult about the G50's?
