Rogue One wrote:eBay. I've purchased multiple filters there for Nissan, Toyota, Honda. Just look for a reputable seller. Work great and a fraction of the cost of OEM.
If you must to have OEM, http://www.infinitipartszone.com/ or http://www.courtesyparts.com/
I do this too every spring or so...just make sure you have the windows down in the car for a little a while after lol.Frog wrote:I sprayed a can of Lysol into the outside vent and the inside vent both on recirculate and outside air. This will kill any mold growth on the ac condenser. Which replacing the cabin filter won't do. Good luck.
Jfpq70 wrote:Did changing the filter do the trick?. I have the same issue on start up. Slight musty smell. Car only has 7k miles.
