Sounds
kds4x4
Car: Baseball/Softball
I have a 1996 200SX and I have this whining noise coming from the engine. When I increase the RPM's the sound also increases with intensity. When I turn on the AC it changes the tone, but the sound is still there with the same effects. Another sound comes from my right tire somewhere. It sounds almost like a rubbing, but it isn't a rubbing. I was thinking that the first sound from the engine was possibly the power steering pump and the secong noise I have no clue about, but was thinking maybe it was either the spindle or the suspension. Can someone please help me this is really annoying and it draws a lot of attention to my car. :help
NISTECH
the engine noise i suspect is your idler pulley for the a/c and alt. the other noise not sure is your axel rubbing the plastic splash sheild? try loosening your drive belt up start vehicle and see if your engine noise is gone. do not leave it this way as your battery will not stay charged w/o the alt.
p00t
the whining is definately from one of your accessories... most likely the power steering, which always makes a slight whining sound, you might be low on fluid or pump may be going out. but try tightning all the belts slightly like NISTECH said.
rubbing sound could be a wheel bearing wearing out... but im not sure. does it get worse when your turning in a certain direction and speed?
kds4x4
It stays constant no matter the speed or if turning or not.
Nismo_Freak
Car: 89 Nissan 240SX
What sort of tires are you using?
kds4x4
stock type tires
