300ZXttZMAN wrote:He means an unbalanced drive shaft
This. It will vibrate is what I mean. That's the only way to put it. Yes the shifter will vibrate, but only because the driveshaft is vibrating, which in turn, is vibrating the transmission, whilh has a bracket connecting to the shifter.
Z1 recommends "rotating it 1/4 turn clockwise" to "fix" the issue. Some have reported that it got better after doing so, but think about the physics of what is being recommended. They're saying to rotate, what they claim to be a centrifugally balanced driveshaft, which means equally balanced in a rotating mass, and turn it 1/4 turn. If it's unbalanced, that won't help. It will just put the unbalanced portion 1/4 turn offset from where it was in the first place. Crap like that sounds shady to me.
David at shaftmasters guarantees no vibrations, because they only use quality components, and ACTUALLY balance their driveshafts, ensuring no quality control errors.
