VG30DE has dual Throttle bodies with a single actuator rod that controls the open/close sequence. It also has a single TPS sensor.
First off, take off both throttlebodies off the plenum and clean them thoroughly. Install the throttle bodies and set TPS and base Idle using the FSM (factory service manual) specs.
Clean the egr valves.. Clean the Idle air control valve..replace PCV valve. Replace plugs.. Here is a link to the Idle valve
http://www.twinturbo.net/ttnettech/iaa/iaa.html Contrary to what the article states, the Idle/AAC valve can be cleaned.. In the FSM there is a test/clean procedure. Replace the O2 sensors..both of them.. $60-70 a piece..
It is not rare for a coil pack to go bad. If you have followed nissan's history..there are notorious coilpack issues on Maxima's..cracking..arcing..windings going south.. replacing a coilpack and plugs will get 30-40% of your power back...You will know what you have been misssing. Just remove your coilpacks and visually inspect them before going down the replacement road.. Injectors are notorious for Jegs quality from the 90's.. Bosch replacements fix the issues
The Air box is indeed restrictive. The exhaust system is restrictive. The ECU programming is restrictive. Transmission is restrictive. After driving my 5speed maxima and then driving this is night/day. However, for a long drive, this car is the only way to go..Cruise all day @70 mph..
The IAC/AAC valve is notorious for low rpm bog..known problem on maxima's..Clean all the parts..she deserves it anyway..you'll notice the difference...
