sounds like bees in my trunk
666-g50
Car: 92 Q45
some one else one the site described this as a symptom, i also have this problem. what could it be. rear diff nooise, fuel pump.....bees?
fun240
Car: 95' S14, 91' NX1600
Fuel pump brother.
Its almost gone.
I would change it before you get stuck someone far from home. But that is what it sounds like.
Just be glad you even got a sound. I didn't get anything, mine just went out! lol
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
You change it immediately with a new one and a new O ring from
http://www.infinitipartsusa.com
You inspect the tank and fuel lines and FPCU because you will need one of those also if you continue to abuse it with a busted FP.
Read Tangalora's most excellent post in IOM.
666-g50
Car: 92 Q45
what am i looking for
goody90q45
Car: 1992 Infiniti Q45 (sold)
maxnix wrote:....You inspect the tank and fuel lines and FPCU because you will need one of those also if you continue to abuse it with a busted FP.....Read Tangalora's most excellent post in IOM.
666-g50 wrote:You inspect the tank and fuel lines...what am i looking for
Deritrus of course. And if you see deritrus in the bottom of the fuel tank then you have to suspect that the fuel lines also contain deritrus and will need to be cleaned. (Inside joke. Sorry)
Chances are your fuel tank and lines are spotless but it is important that you replace the $220 fuel pump before it destroys the $700 FPCU. As Brian suggested you should also check the FPCU for a melted connector and look at its internals for any anomalies.
Q45tech
Water drops and thus tiny rusty piles settle in the center metal cup where the pump strainer sock sits.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Even just a very discernible film on the bottom interior of the tank will foretell a short life for the replacement pump.
