silpena »
https://forums.nicoclub.com/silpena-u34788.html
Tue Apr 24, 2007 7:45 pm
why not? i'm going to support the car on jack stands and use a support for the cross member and instead of removing the engine mounts and hoisting the car up to give me the clearence i can put a block under the oil to protect it and jack it up to give me the clearence to get into the hard to reach area's of the oil pan then lower the car down slowey with the front bolts still in so i can unbolt it then just slide it out. Sounds like it would work i looked and thought about it for like 20 min under the car seeing it could work i need to know if it will damage the oil pan or the enging or anything else i doubt anything will fall on me... the engine should stay in since the motor mounts are still in and if i have to, i will lower the cross memebr a couple inches like in the fsm says too. If surely this not a safe way then i guess i'll just rent one... but i don;t have alot of money to spare..."damn taxes screwed me up this year" any help would be good, i hacn';t been with my 240 for like 3 months i'm really anxious to get it back runing.
