sound systems
vancouverpath
Car: 2001 Nissan Pathfinder XE
I'm thinking about putting in 1 or 2 10" subs in my 01 pathfinder. If anyone here has a subwoofer set up do you mind putting up some pictures? I don't want to lose much trunk space and i am looking for some inspiration.
ALso, does anyone have any alternatives ideas regarding subwoofers? Thanks
bullrid
Car: 01 Pathfinder LE
here are some pics of my 01 pathfinder. i have 2 12s in them. the box is fairly deep which it doesnt need to be. sounds amazing having it aimed straight back. the depth of the box can definitely be cut back with 10s.
vancouverpath
did you keep your stock bose headunit? where didyou mount your amp for your subwoofers?
Thanks
bullrid
i kept all stock radio head unit, just tapped off the rear speaker lines. the amp is mounted on the back of the box against the back of the rear seats.
silveradoSS
boooooo 10's , 1 12 and you will love it, here's mine and its for sale because I no longer have my pathfinder, if you are interested, we can work out a deal.....
youngcoke
GO WITH 4 15 INCH .. YES!your hairs on your nose will shake
