1BluCoupe wrote:well im trying to install a amp and sub i have the converter and it is wired but the amp isnt turning on. its all wired correctly as far as i know. ive done over 20 amp sub systems but this is the first one with the converter...
if you have the scoche line output converter, and you're running an aftermarket amp, you need to make sure you connect the ground corectly, and change the position of the black tab on the side!
Also, as mentioned, be sure you have connected the remote on on the amp, to the correct wire on the factory harness!
