Sound system
socalred
Car: 2008 g35 4d black
I have a 2008 g35 with bose and navi. Wanted my subie sti system back. Can I put a pair of rockford amps, 2 front components rock ford and a rockford sub in it and keep the navi? also can i trick out the navi so i can operate functions that are only accesible when stopped? thx
smockers83
Car: 2006 G35 Coupe
As for the system, yeah you can. You can pretty much do whatever you want these days. Your amps just have to be able to accept a high-level input, and they should if they're relatively new. You'd just hook it up through the factory speaker wiring.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
you have a lot of options here, it really just depends what you want to do.
In fact, some have just replaced speakers with other low impedence speakers and have loved the results.
Me personally, i replaced it all...
socalred
I'd like a wall with the sub centered and the amps on either side. Will the quality be good enough using the speaker wire? Aren't the bose amped already? That'd mean they go from head unit to amp to another high power amp and then speakers. I have several grand in products I want them to sound excellent! Anyone else integrate an aftermarket system with navi? If so how'd you do it? Thx!
I have*T112D4 12" POWER T1 4-Ohm DVC Subwoofer
*T162S 6.5" 2-Way Component System
*6001bd mono amp(sub) 600w rms 1200w max
*and a 4 channel it's the older chromed out style
