Simmsled »
https://forums.nicoclub.com/simmsled-u3103.html
Wed Aug 03, 2005 4:32 pm
Ok, so... you have a nice start here. I see that you are using your amp to power your fronts and your deck for the rears. Good man. I believe that your amp has a variable crossover frequency between 40 and 130hz. I would set your crossover at around 70hz as to not completely buzz your doorpanels off. Your gain for left and right should be the same level and as you turn up your radio from zero volume, you should hear your fronts a bit more than your rears, so adjust your gain accordingly. If you find that changing your crossover on your amp does nothing, then you will have to select high pass on your amp, or turn off the crossover built in to your pioneer cd player. You can find the crossover menu in the sound options on the cd player.
Remember, your Bostons will play louder with less distortion the higher your x-over is, but at the expense of midbass. forget about trying to get your speakers to play down to 40hz in your doors. It is possible, but takes WAY too much dynamat to accomplish successfully, especially with as much power as you are sending to them. You know you are done with gains when you can turn it up to a desireable volume and there is no distortion.
Now... Pioneer has many wacky EQ settings on their units. I usually have found most of them pretty much worthless at volumes higher than 1/4 way up the scale. I would set custom and use these settings:
High +2Mid -2Low -2
Make sure that in your menu on the deck that the FIE (front image enhancement) is off and that SLA (signal level adjustment) is not touched. If you really want to know why, I'll tell you but its basically a bunch of crap.
This should make you happy for now. If I have confused the crap out of you, let me know. If not, ENJOY!!!
