Sound System Problem, Causing Other Things..
MEAN1NGoFLIFE
Car: 1993 Nissan 240SX SE
i recently installed a new sound system in my car
two 10" pioneer premier championship series pro, heres all the specs.
http://www.pioneerelectronics....%7CD4
im also running on a 760 watt pioneer amp.
http://www.pioneerelectronics....5300T
my concern is because i noticed all my lights dimming out and what not. i did look up alot of stuff but still confusion.
i also even got a 3 farad power acoustik capacitor installed and still have the same dimming.
i plan on buying a yellow top optima battery anyway because my battery is extremly old and would be very useful for alot of electronics.
i just want to have this kick *** sound system and not have to worry about any alternator problems.
suggestions?
onosqv
Car: '92 240sx Vert
you can upgrade to a high output alternator - you can do a search for "alternator upgrade" or "quest alternator" or something like that.
changing the battery probably won't hurt, but you might still get some dimming if your system draws too much power - less likely w/ an optima battery, but a battery can only do so much.
justin240
Car: 1989 nissan 240sx
get a higher farad cap, there are some out there that are upwards of 100 farad
theother1wstolen
Car: 92 240sx Coupe SE
i have a 3farad cap and a second duralast gold 1100amp battery in my trunk, and even with my 8000 watt setup at max my headlights dont dim anymore. just a thought. you should get an isolator for a second battery tho.
mtparker18
You have to do the big 3 upgrade, http://www.the12volt.com/insta...~PN~1
It says after upgrading alternator, but I know people who just upgrade their grounds to 1/0 gauge and don't have dimming problems with stock alt.
I don't think Caps work at all. I've hurd mixed reviews about them, I have one in my lexus and my lights still dim. fyi
hope that helps.
theother1wstolen
i agree, the first thing i bought was the cap. my lights still dimmed so i upgraded my grounds, and put a second battery in, havent had a problem with it since. and thats on the stocker 85amp alt. i would like to upgrade just for peice of mind tho. ive had a couple cars with 110amp alts and didnt use the second battery and i didnt have any dimming problems in those.
