240crawler »
https://forums.nicoclub.com/240crawler-u29033.html
Fri Jun 10, 2005 4:43 am
On the s13, you can drill a hole below and a little to the passenger side of the brake booster. This location allows you to run the wire from the hole, under the fuse panel cover (kick panel), and under the carpet when you remove the door sill. Remember to run the cables inboard of the seatbelt bracket, and under everything possible for the cleanest line. I have 2 4-0ga. cables for my power, and you can't see anything. Powered by JL Audio!!!!!!!!!!
