Sound Setup/ Center Speaker?
Geronimo77
Car: 1990 Nissan 300zx Twin Turbo
i have a 90 300zx and none of the speakers work except the center speaker below the head unit. i was wondering if i could replace the system while keeping the center speaker
P3ngy
Car: 1994 300zx Twin Turbo(Sold)
1992 240sx (Sold)
Supra Swapped 95 E36 M3 - (Sold)
93 240sx (Daily Beater/Slider)
Yes, speakers are interchangeable. Just make sure your head unit has enough watts to power your new aftermarket speakers at their RMS rating + enough for your additional stock speaker.
Geronimo77
alright cool. do they make aftermarket center speakers? and i was looking at the brackets for new speakers and they say they fit 5.5" - 6" speakers, do they have some that fit a 6.5" speaker?
skinZ32
Car: 1992 300zx 2+2
yes. you can get aftermarket brakets for your doors and rear speakers to fit 6.5 all the way around. i got my off of ebay for like 20 or 25 bucks they were made out of 5/16 plastic and fit perfectly in the doors and rear. i also add to pull out the pre-amp for the bose speakers
BROOKSZ
Car: 1993 300 ZXTT
If your system is the BOSE system, then you need to check your impedances. Mine, for example was BOSE with 2 ohm speakers. If you replace the speakers with conventional speakers, you will have a 4 ohm load instead of a 2 ohm load which will make the amplifier that they are connected to put out only half of the power of the previous speakers. If you want to learn more, go to http://www.the12volt.com. They have a wealth of info.
curtiscr87
Car: 2008 Infiniti G35x
2011 Nissan Sentra
order your speakers off of crutchfields they have the best quality and can help you with everything check out the website:http://www.crutchfield.com/S-VYeTSgXXFkS/
cfor3
Car: 1992 nissan 300zx na
Yes, there are aftermarket center channel speakers avaliable for your Z. Alpine probably has the best unit, model # SBS-05DC, for the Z. I have this unit for sell if you or anyone else is interested. Check out your charter.net email for more info. Letting this brand new speaker go for $100. Email me at [email protected]. Frist come, first served!
Modified by cfor3 at 10:22 AM 6/13/2008
