rover3l »
https://forums.nicoclub.com/rover3l-u10518.html
Fri Nov 28, 2003 12:31 pm
Coated my underside (the cars not my own!) with a good layer of undersealing compound and also the plastic wheel arch liners. It has definately reduced road noise. It messing around I discovered some further opportunities for noise reduction that might be of interest to Elwesso in particular:
1. Rear side of front wheel arch line nearest door has a layer of foam. I suspect for noise reduction. I am going to investigate whether this can be improved further.
2. Front kick panels provide an opportunity for adding some foam also. I am thinking foam rubber not the spray on type.
3. In the trunk, removing the carpeting at the sides reveals a major area for noise reduction. It is possible to shove foam up into the roof pillar area which is double skinned and hollow. Also foam can be glued to cover the wheel arch
4. Under the spare wheel is another area to apply a sheet of foam and also to the rear of of the verticle carpet panel that hides the fule tank.
5. The A and B pillars can be treated with expandable foam from an aerosol
6. After removing the door trims a layer of asphalt roofing sheeting can be glued or tape on over the polyethylene barrier
Have fun
