Sound of destruction?
zxFarside
Car: 94 300zx TT (sold)
03 Suburban 5.3
00 BMW 323
My car dose this weird thing when you drive the car when the engine is cool, say the first drive of the day of if the car has been sitting 3+ hours.
When you turn the car on then start to drive it will hit 2500-3000 RPM kinda hesitate and make this sound that I can really only describe as someone taking a wrench and hitting it on something metal or maybe a small firecracker under a metal bucket.
It only dose this once or twice then it runs fine. If the engine is warm or I let it warm up for maybe 10min it wont do it.
I haven't the slightest idea what it could be and I can't really show a mechanic because it wont do it unless I leave it with them overnight.
es.biggs
Car: 1990 300ZX 5sp NA
Not sure man...I'd start with ignition timing. Use a timing light to check it. I just bought one and fixed my Z with it lol. If you ever want some help or need to borrow a tool or anything, holler at me man I'm right down the street from you!
zxFarside
03 Suburban 5.3
00 BMW 323
My timing should be right at 15* I just had it set maybe a month or so ago at 3SX.
DanDrath
Car: 1990 Nissan 300ZX 2+2 TT
is it a backfire? haha
zxFarside
03 Suburban 5.3
00 BMW 323
That's what it may be. I don't know what could be causing it though. O2 sensor maybe?
DanDrath
maybe a bad o2. Probably a failing injector. ohm test the injectors or do the screw drver test ( put a long screw driver up to the top of the injector (assuming u know where they are) then put ure ear to the driver ull hear it going tick tick tick listen to all 6 injectors if ne of them sounds very different then the others or more than one sound very different its probably a problem with that injector. U can temporarily fix it by smacking the screw driver with a hammer lightly will free up a stuck injector.
zxFarside
03 Suburban 5.3
00 BMW 323
I'll have to check the injectors, I have 4 new ones and 2 old ones lol
tmeyer29
Car: 1990 300zx TT , 04 Yamaha R6
preignition
camlbi
Car: 1991 300zx TT KH2,
1991 300zx TT Silver
could be a lifter sticking
zxFarside
03 Suburban 5.3
00 BMW 323
I do occasionally have that lifter tick.
Anyone know roughly what a total engine rebuild would cost?
