bstevenson »
https://forums.nicoclub.com/bstevenson-u28416.html
Wed May 04, 2005 5:49 pm
ok, so i took the valve cover off today and checked it out, the top side of the timing chain is tight. . .the passenger side where the tensioner is located is tight, but the drivers side is slightly loose, has about 1/16" - 1/8" play.
The engine was installed in the car last year, before I got the car and is supposed to have about 60k on it. It is marked from the place that installed it that it had 54k when they had it. Now you can tell from the looks of the engine that it sat for a little while before being installed in my car. So my best guess is that there is a build up around the tensioner that is not allowing it to tighten up completely. Does this sound right. I am probably going to actually start pulling it apart tomorrow to see if I can find out. I was going to do it today after I did my brakes but I ended up having to do some engineering on one of the calipers so it took longer than I thought.
But anyways, any help would be great. . .thanks guys
