paigoomein wrote:anyone have instructions/steps on how to remove the rear seat for installation?
options28 wrote:OK Mark, the foam arrived today and I installed it as you instructed . It was an easy fix and after test driving, I too am impressed with the quiet it brings to the cabin. In my opinion well worth the $60 investment(includes shipping) for the 1/2 inch sheet.
In the trunk I just cut the foam to match my cargo mat as it is well contoured to the floor, layed the foam on the trunk floor and the cargo mat on top of the foam. When I removed the rear seat the green felt pad was moved to the rear of the seat and thus not insulating as it should.
Used the pad as a template and then layed it back on top of the foam after it was cut to fit.
It was all easy and really does make a difference, I was skeptical but it does work.
Stan
Relentless got it! Pull the too tabs and out it comes. The back part is only four bolts located around where all the seat belts attach. I am planning on coming at that area from inside the trunk but I did Dynamat that and you could put a 1/4" or so layer in that area? Just have to make your own template or cut around stuff like the trunk pass through.
MArk
