true. so you could put the dampening material on the outside of the plastic cover, the one that's in contact with the actual door panel. That protection should be sufficient.juiceman wrote:Be sure to do it correctly as water does flow thru a door when it rains. You do not want to trap water in there and make an environment that produces rust.
diamondj30 wrote:what is your goal.mcmaster-carr online ,they have visiolastic and high temp mastic.it is very cheap compared to dynamat and cascade VB-2 and is exactly the same with out the silkscreen name on it.you will need a heat gun,go to home depot they have insulating rubatex rolls.
Sopdadope wrote:In my experience, nothing beats sheets of Brown Bread. I ordered it online somewhere. You can buy it by the yard and it's relatively inexpensive compared to dynamat, Road Kill spray insulator.
Removing the door panels are easy, but the carpet is a whole other story. To properly remove the carpet, you'll have to take out all seats. There is some insulation there already, but you can never have enough sound deadening.
For the wheel wheels, use rubber undercoating sprays, it works great. My car's the quietest Q around and I know this for a fact (80 lbs. worth of Brown Bread and dynamat in the doors) but things can get pretty wild when I crank up the stereo!
Good question. I was thinking about the same thing.greg_atlanta wrote:Is there any benefit to adding insulation between the trunk and the back seat? Lots of dead space around gas tank, easy to access compared to door panels.
csoluri92Q wrote:One thing I noticed in 3 of the doors was the factory "glue" used to attach the door skins to the center door frame had come loose, likely causing much of the door skin vibration. Chris
Wow... completely crossed the wires on that one! I never even thought to look in there that far! I'm not sure I want to take "Q2" apart again anytime soon, but if I do I'll sure check it out.csoluri92Q wrote:Heath,
The glue I was referencing are extremely brittle blobs (after 10 years anyway) used to hold the outside door skin (the painted sheet metal) to the center door beam which runs horizontally down the middle of the door. i suspect the door beam provides the structural strength in the case of an accident. The plastic sheeting under the door panel does use a very sticky black putty. I was able to pull it off with the plastic and simply reattach the plastic when I was finished. I hope this helps!!
natsoundup wrote:Boy, have I been ignorant.... I am going to order this stuff for both the Q and the Expedition.... a place on the internet has 36 sq feet for 140 dollars for the Dynamat Extreme..
Anyone try B-Quiet Extreme...it seems like a generic.
AGM wrote:I can't remember what brand of sound dampening I used as it was done by my motor trimmer. The material was similar to the sheet you put over you when you have an Xray. It feels like a peice of material made out of lead.
The trimmer affixed the material directly to the door trims, so it is actually part of the door trim, not part of the door. Did the rear parcel shelf right up to the underside of the carpet to the driver seat. The material used in the doors was not as heavy a gauge as the rear parcel shelf area, as ther is less room in the door panels to affix the material.
There is an improvement, but not as much as I expected.
Another option is 'noisekiller' made by rocksford fosgate. It comes in two options of cans, one for painting on with an spray gun and the other in an aerosol can you can spray on yourself.
I would go for the aerosol can if you do not have the correct spray gun and nozel.
Regards
AGM
brucepelletier wrote:Is Noisekiller the brand name? Where is it available? Do you think it would be good for the wheel wells? With the Bose speakers out I'm hearing tire noise which is very annoying. Has anyone ever removed the plastic wheel well liners, sprayed sound dampening on the rear and reinstalled them? I can get to the rear wheel well bodywork on the inside through the trunk but can't figure out how to sound proof the fronts. Any experiences?
