sorry to ask but will these wheels fit??
ytboy4ever
Car: '87 TII
'92 Coupe
'86 CRX - dd
I am sorry to ask and I have done some research and searching but I am having trouble coming up with a definite answer.
The wheels in question are 16x7 (+31) and 16x8 (+35)
The car is a s13 coupe and I will be running coilovers.
My concern is the 16x8 on the rear, the wheel offset calculator says there will be 20mm less spacing on the inside. With negative camber and coilovers will there be a problem.
Also what kind of tires sizes can I run, I have 16x7's on my rx-7 (FC, stock wheels) and I run 225's, can I run the same size on these wheels on an S13??
Thanks in advance for any answers.
SmithSR
Car: 240sx
Those sizes will fit fine.The rear has much more room than the front.A conservative size option is:205/55-16 F225/50-16 R
Those sizes have the same overall diameter as stock and you can get really good tires in those sizes, and still have a conservative looking car that stays below the radar..if that's what you want
ytboy4ever
Car: '87 TII
'92 Coupe
'86 CRX - dd
I was thinking more along the lines of 225 all around.
so I won't need a spacer in the rear?
